Shade brings together advanced 3D modeling, rendering and animation into an integrated whole. By exporting
iClone character motions via 3DXchange, your Shade characters
can be connected to a library abundant with motions.
Before starting this pipeline, you need to prepare a biped bone structure in FBX format
from Shade.
Step 1: Loading and Characterizing Shade Bone
Load the prepared Shade bone structure (in FBX format) into 3DXChange.
Manually drag and drop standard character motion files into the Motion Library; select one of the
motions and click the play button to preview.
Please refer to the Using Motion Library section for more information.
Note:
Click the Explore button to browse to the default folder for storing the
iClone standard characters motion files. Windows XP: C:\Documents and Settings\All Users\Documents\Reallusion\Template\iClone 5 Template\iClone Template\Motion Windows 7 or above: C:\Users\Public\Documents\Reallusion\Template\iClone 5 Template\Motion\
IMPORTANT: If you drag and drop motion files in FBX or BVH format
to the Motion Library, then you MUSTcharacterize the character
again so that these motions will be automatically converted into iClone
compatible
standard motions.
Add desired motions into the Perform Editor. Only the
motions added into the Perform Editor
are candidates for FBX export.
Please refer to the Using Perform Editor section for more information.
Step 3: Exporting Motions in BVH Format
Execute the File >> Export to Other 3D Format >> Export BVH... command.
Alternatively, you can click the Export BVH... button on the tool bar.
Adjust the settings in the Export BVH panel and click the OK button to export all motions
listed in the Perform Editor into individual motion files (*.BVH).
Note:
You must click the button to designate one bone as the motion root in the
Scene Tree panel.
Basically, you need to select the bone that is mapped to the Hips node of the dummy in the characterization mode.
Step 4: Loading the BVH Motion to Shade Character
Go back to Shade, execute File >> New to new an empty scene.
Execute the File >> Import >> BVH command
to import the exported FBX motion file to the new scene.
Select the motion root node (in this case, the Pelvis) of the structure
from the Browser panel.
Open the Motion panel.
Drag to select all keys on the timeline.
Click the Save button at the right-top of the panel to save the animations
of each bone into a
Shade motion file (*.shdmtn, *.mtn).
Switch back to the scene with the original bone structure.
Click the Load button in the Motion panel and load the
saved motion file in the previous step. Only the first pose is loaded to the bone.
Click the Load button to load the file again. The motion is
then applied to the bone.
