The basic workflow for using the Application Templates is shown below: |
| Step 1: Preparing your CrazyTalk Interactive Assets | ||||||||||||||
To create Unity compatible assets (character and motions) from CrazyTalk, you may need to follow the steps below:
| Step 2: Modifying the UserSetting.js File | ||||||||||||||
In this step, you are about to introduce the prepared assets into the web player by modifying the parameter settings in the UserSetting.js file. In this step, the actor is taken as an example to show you how to replace the actor with the prepared one.
| Step 3A: Placing HTML Codes to Custom Web Pages | ||||||||||||||
| Step 3B: Embedding Templates on Server to Custom Web Pages | ||||||||||||||
If you do not want to use the copy-and-paste code method to embed the Application Templates into your web pages, or if you need to embed multiple Application Templates at the same time, then you may need to follow the steps below:
