Editing the Prop Background Mask (New for 2.1)
The background mask hides all unnecessary areas of the loaded photo. This helps you keeping only the areas you are interested in, such as the furniture in a photo.
Original prop image
Masked prop image
There are two methods to generate a background mask for your image.
Using Mask Editor Panel
  1. Make sure you are in the composer mode.
  2. Click the Mask Editor button at the tool bar to access the Mask Editor panel.
  3. Using the tools in the panel to paint on the unnecessary parts in the image to add mask on the image.
    There are two modes in the Mask Editor which facilitates you to quickly add mask to the image:
  4. Click the OK button and the colored area of the image will be filtered out.
Zoom Tools in Mask Editor
Loading an Image with a Predefined Alpha Channel
If you wish to perfect your image mask, then you may pre-save your image with a pre-defined alpha channel. This can be done by means of an external image editor. Once you create your mask outside, simply load the image into CrazyTalk Animator. The alpha channel information will automatically be applied as the background mask in the Background Mask Editing panel.
Adding and editing alpha channels in an external image editor (e.g. Photoshop)
Note:
  • The alpha channel information can be in 32-bit BMP, TGA or PNG format.
  • If you wish to save the source image as PNG file, then remove the background layer, erase any unnecessary area of the image and save. You do not need to create an alpha channel layer in the Channels panel.
  • Please also refer to the sections below for more information:
