User Interface Introduction for Refine Face
Step 1 - LOAD IMAGE
A
Step Navigation Tabs
Three numbered tabs at the top indicate the current refinement stage:
  • Load Image: Import a side head source image.
  • Align: Set facial control points anchors.
  • Adjust: Adjust the scale and transform of the side head mesh.
The active tab is highlighted, and users can switch stages as the workflow progresses.
B
Image Preview
Display the loaded front face photo. There are three methods to load photos:
  • Double-click.
  • Drag and drop an image.
  • Click the Load Image button.
C
Load Image
Open the file browser for selecting a source image.
D
AI Image Generator
Click to open the AI Image Generator panel.
Step 2 - ALIGN
A
B
Load Image
Load Source Image of side face.
C
AI Image Generator
Opens the AI Image Generator panel.
D
Selection Tool (Q)
Switches to select mode for picking control points.
E
Camera Manipulation
Tools
  • Zoom(Z): Used to zoom in and out of the scene.
  • Pan(X): Pans the camera.
  • Focus(F): Press to zoom on the selected control points.
  • Reset View: Reset the camera to default point.
F
Control Point Size
Changes the size on the control points.
G
Control Point Opacity
Changes the visibility of the control points.
H
Work Area
  • An indication tip to show where you should put the control points (crosshairs). To understand better for Control Point placements, please refer to the page Front Face Control Point Placement Guide.
  • Drag and position the control points (crosshairs) to the eye corner and lip corner.
Step 3 - ADJUST
A
B
Load Image
C
AI Image Generator
D
Selection Tool (Q)
E
Camera Manipulation
Tools
F
Mesh Opacity
Change the visibility of the dummy head mesh.
G
Work Area
  • An indication tip to show how to transform the dummy head mesh to align to the side face image.
  • You can observe the transformation of the head mesh and the side face image.
H
Adjustment Sliders
  • Move X: Adjust the slider to transform the head mesh along the Y-Axis.
  • Move Y: Adjust the slider to transform the head mesh up and down along the Y-Axis.
  • Scale: Adjust the slider to change the scale of the head mesh.
  • Rotate: Adjust the slider to change the rotation of the head mesh with the corner of the eye as the rotation anchor.
I
FINISH
Click after adjustment to finalize the Mesh Placement and enter the next stage.
