Click this button to connect the console to the
Axis Neuron application for
receiving motion data from it.
Click this button to open the panel for
Server Settings.
Local:
If the Perception Neuron is installed on your local machine,
then choose this radio button. Remember to enter the
identical port number
as you have set in Axis Neuron application
(it is 7001 by default).
Network:
If the Perception Neuron is installed on another computer on the network,
then choose this radio button, type in the IP Address and Port of the computer and then
click the Connect button again to receive motion data from the plug-in on that
computer. It is useful when the other computer is faster than your local computer.
3
Use these two controls to map the virtual characters in iClone to
the ones in the Axis Neuron if you want to have
motions
captured for two characters.
4
Switch between these two tabs in order to capture
the motion of the entire body or merely the upper
body.
5
Use the dummy to filter out the motion of the body
parts you do not wish to capture. Please refer
to the Multi-Layer Capturing section for more
information. |
6
Click on these two buttons to view the Preview, or Record the captured motions. |
