Exporting Flattened Material Images
  1. Create a new project.
  2. Apply one of the templates from the Skin or Makeup libraries (in this case, Makeup).
  3. Go to the Skin or Makeup page under the Appearance tab in the Modify panel corresponding to the template.
  4. Select one of the layer.
  5. Freeze or flatten the layers of a material.
  6. Right-click on the layer to show the Context Menu. Choose the Exporting Flattened Material Images command.
  7. Pick a folder and click the Select Folder button.
  8. Open the folder. You will see a folder with a same name as the layer's name.
  9. Open this folder, you will see folders of the channels' name.
    The textures will be stored in these folders.
