Editing Pack Information (New for v1.2)
After you have created a custom pack and add custom contents into the pack, you can edit the information of the pack before upload it to the server.
- Right-click on the custom pack and choose the Edit Pack Info... command from the context menu.
- Set the data in the fields of the Edit Pack Info panel.
- Load Thumbnail: You can click this button to load a custom image as the pack's thumbnail.
- Pack Name: You can type in this field to name or rename the pack.
- Description: You can type in the description for this pack.
- Base Type: This field shows the character type.
- Category: This field shows the category of the item.
- Subfolder: You can add the item into the subfolder of this pack.
- You can click the Upload button to save the information to the pack and directly upload the pack to the server.
- If you click the Save button, then the information will be saved to the pack.
