Moving Contents between Custom Packs (New for v1.2)
If you want to move your contents between custom packs, then you can perform the following step:
- In Smart Gallery, make sure you have created several custom packs under the Custom node.
- Make sure you have added contents to the Custom pack.
- In this case, double-click on the Custom pack to open it.
- Select the contents that you want to transfer, notice that multi-selection is allowed.
- Right-click on the selected item and execute the Move to Pack > [Target Pack Name] command (in this case, My_Custom_Pack).
- Click on the Back button to exit the current pack.
- Double-click to open the target custom pack.
- As you can see the items are now moved into this pack.
- Switch back to the Custom pack and select items again.
- Execute the moving command again, but choose the Create Pack command from the sub-menu.
- Type in the new pack name and click the OK button.
- Click the Back button to exit the Custom pack.
- As you can see there will be one more pack added.
- Double-click the pack to open it, as you can see the items are moved into this pack.
