Exporting iAvatar Panel Introduction
When you want to export a CC character into iAvatar, the Exporting iAvatar panel can be used to export a character with complete details or the remeshed one for optimal performance.
A |
The maximum resolution for the exported texture size of the iAvatar. |
B |
You can adjust the texture quality and size for the iAvatar. Keep in mind that the texture settings in the Detail Quality list is for the textures that can be adjusted by the Appearance Editor, but the skin textures are not included. |
C |
Remesh settings for optimized iAvatar. |
Exporting Characters of Character Creator 3
If the character is from Character Creator v3, then you can only determine if you want to remesh (to change the polygon count) when you export it as an iAvatar. Keep in mind that the texture settings in the Detail Quality list is for the textures that can be adjusted by the Appearance Editor, which means the skin textures are not included.
Exporting Characters of Character Creator 1 or 2
However, if the character is from Character Creator v2 or earlier version, then you can adjust the texture quality and size for the iAvatar. Keep in mind that the texture settings in the Detail Quality list is for the textures that can be adjusted by the Appearance Editor.
