Converting CC1, CC3 to CC3 Base+
- Open a project or load a character (CC1 Base or CC3 Base) that is created from or embedded in Character Creator v3.2 or earlier.
- Open the Modify panel. Switch to the Attribute tab, in the Avatar section, click the Convert CC3 to CC3+ button.
If the character is CC1, then the button label becomes Convert CC1 to CC3+. - You can determine the final texture size after conversion:
* Note that the either selection inevitably degrades the textures for the conversion.- Keep Original Size: Convert all textures to CC3 Base+ compatible textures in the original size.
- High Quality (4K): Some of the textures need to be converted to 4K (4096 x 4096).
- Medium Quality (2K): Some of the textures need to be converted to 2K (2048 x 2048).
- Character Creator will show the following warning message:
- OK: Continue conversion.
- Cancel: Abort conversion.
- After conversion, you can choose to apply Enhance Eyes for close-up on the face and manually fix penetration issues for the clothes.
Penetration-fixing methods: If you encounter the poke-through issues after conversion, you can use the following methods to fix the problems:- Hide Mesh
- Conform: procedure to fix the penetration issues
- Re-apply the clothes again (for Free Version users)
- Transfer Skin Weight (for Pipeline Version users)
