Sharing Template Content
There are resource packs or content packs with shared items like characters or motions, which can be applied in both iClone and Character Creator. You can install only one pack in one template folder location and share it with these two applications.
The following example will show you how to install a purchased pack in iClone and apply it in Character Creator.
In iClone, click the Menu button in Content Manager and execute the Settings command.
The Settings panel will show with the default shared folder currently used between applications.
You may change the Template Folder path to another folder for installing the packs or items.
Click the OK button.
Purchase a content pack, and then download and install it in iClone.
Double-click on the pack to view items inside.
You can see shared items such as ccAvatar, ccHair and ccCloth.
* Make sure the Show Subfolder Items checkbox is enabled to view all items in the subfolders. -
Right-click on the item to find content files in the Windows file explorer with the specific directory.
In Character Creator, execute the Settings command in the Content Manager menu.
The default Template Folder path in the Settings dialog will be the same one as in Step 2.
If you have ever changed the shared folder path, must manually set to the identical one.
Select the New Purchase filter node to find the same pack in step 3.
It will show installed because the pack already exists in iClone.
* If you find the pack appears uninstalled (greyed-out), then double-click on it, or click the Refresh
button to sync again.
The thumbnail will be colored. -
You can see shared items with iMotionPlus and iTalk formats.
Right-click on the item to confirm content files in the Windows file explorer with the identical directory.
iClone and Character Creator can now share the use of this installed pack.
- You can apply not only a character, but also a motion in Character Creator.
- Save it under the Custom tab and then you can share custom contents with iClone.
