How to adjust Dust effect
Before starting to adjust the Dust effect, you have to be familiar with createing Lens Flare Layers and Layer Types - Dust.
The characteristics of the Dust effect are:
- It settles down to simulate the dust or stains sticking on the lens.
- Can be lit by the gizmo.
- Make sure there is already a Lens Flare effect in the scene, and the effect contains at least one Dust layer. In this case, there are multiple layers to simulate the fingerprints and the grease on the lens.
In the example of this page, there are 5 dust layers in the list.
- You can also change the texture to create different Light Source effects.
- Open the General Attribute sub-section.
Dust SizeThis value determines the circle size of the area for the image layer to be lit.
Dust Size = 20.00
Dust Size = 50.00
ScaleThis value scales the image layer of the dust effect.
Scale = 1.00
Scale = 11.00
Scale X and Scale YThese two values horizontally (X) or vertically (Y) scale the image layer of dust.
Scale X = 1.00
Scale Y = 1.00
Scale X = 0.50 (Horizontal)
Scale Y = 1.00
Scale X = 1.00
Scale Y = 0.50 (Vertical)
BrightnessThis value sets the brightness strength of the image layer of the dust.
These two values scale the image layer horizontally (X) or vertically (Y).Brightness = 1.00
Brightness = 10.00
RotationThis value rotates all image layers clockwise.
These two values scale the image layer horizontally (X) or vertically (Y).Rotation = 0.00
Rotation = 230.00
Offset X and Offset YThese two values horizontally (X) or vertically (Y) can offset the image layer for the dust.
GlowThis checkbox can be activated to create a glow effect around the image layers.
Glow = OFF
Glow = ON
