How to create custom Lens Flare Layers
After applying a Lens Flare template from the Content Manager or creating a Lens Flare effect from the Create menu, you can add more layers to the lens flare effect as needed.
- Make sure to have a Lens Flare effect in the scene.
- Select the Lens Flare gizmo. Go to the Modify panel > Material tab > Layer List section.
- Add one more layer by clicking the Add button.
Alternatively, you can click the Duplicate button, which can duplicate the currently selected layer to generate a new layer with same settings.
In this case, we'll be adding a new layer. - A new layer will be added into the list with empty texture channel and default settings.
- Double-click on the name to rename the layer.
- Choose the type for the layer (in this case, Decoration).
- Load an image into the texture channel.
You can see a custom lens flare layer appearing on the viewport.
- Adjust the settings in the General sub-section.
You can create various Lens Flare effects with these steps at will.
- Optionally adjust the settings in the Trigger Zone sub-section to define the color and brightness shifting behavior when the light source animates. Please refer to the How to use Trigger Zone section for more information.
