How to adjust Lens Flare Layers together
In order to adjust the overall effect of the layers in a Lens Flare object, you can access the parameters in the Modify panel > Material tab > Global Settings section.
- Scale: This slider scales the image size of all flare layers.
Scale = 1.00
Scale = 5.00
- Brightness: This slider determines the brightness of all image layers.
Brightness = 1.00
Brightness = 10.00
- Center Offset X and Center Offset Y: The values are the Anchor (end point) position on the screen.
Horizontal Center Offset X and Vertical Center Offset Y Axis
Center Offset X = -1.00, Center Offset Y = -1.00
Center Offset X = 0.00, Center Offset Y = 0.00
Center Offset X = 1.00, Center Offset Y = 1.00
- Color: You can use this color picker to tint the flare layers.
Color = #FFFF00 (yellow)
Color = #00AAFF (light cyan)
- Culling: The fade out settings for the Lens Flare when the gizmo exits the viewport.
- Directional Decay: The settings for directional Lens Flare effect.
- You can click the Glow Settings button to further adjust the glow effect.
