Creating Props with OBJ or FBX Files
iClone supports OBJ and FBX import without changing the node hierarchy or structure of the original file.
Create an environment in a new project.
- Go to File > Import > Import... (Ctrl + I).
Select a file in either OBJ or FBX format.
* You can also drag and drop the OBJ or FBX files into iClone viewport.
- If the object is composed of several element meshes, then you will encounter the following dialog:
Click Yes or No buttons in accordance with your need.- Yes: Keep the original hierarchy as in the OBJ or FBX file.
- No: Merge all the meshes together.
- The object will be imported as a prop in iClone.
