The Prop Puppet feature helps you move your mouse and trigger the prop to transform, while the transform animations are all being recorded. This method saves time when setting a bunch of individual keys for moving, rotating or scaling; in addition to that, the smoothness of the animation is higher that what you can achieve by manually adding keys.
button under the prop animation tab of the Modify panel.
button and then the space bar; move your mouse and preview
the movements of the prop (Shortcut: Space bar).
move your mouse and record the movements of the prop.
Note: |
