Distributing Props on the NavMesh (New for v. 8.4)
You can propagate select props onto a NavMesh using iClone's prop distribution tools.
- Start a new project.
- Create a NavMesh.
- Launch Prop Distribution panel.
- Choose the range by picking the
NavMesh. You will see the placement marker are automatically generated within the range.
- Notice that the Generation Type is limited to
Random.
- Adjusting the settings in the Options section.
For more information, see Generation Type and Option settings. - Add the desired props into the candidate pool. These props will
be sourced for distribution.
For more information, see Distribution Pool Adjustments. - Click the Deploy Props button to place the candidate props.
As you can see the props will be placed on the markers. - You can keep adjusting the settings in the Options section to
achieve the ideal deployment of the props.
- Close the Prop Distribution panel to lock in the distribution.
- Utilize the Align Object functionality if necessary.
The selected props will be align correctly. - Align the props on the other side.
