The Quiz template helps you create interactive quizes for audiences. The number of questions in the quiz can be changed
and the total number will be auto-calculated at the end of the quiz.
The actor can also give a default or customized comment according
to the score. Please refer to the Basic Workflow section to create and build desired interactive assets before proceeding with the steps below. Once the assets are properly stored in the folder mentioned in the Basic Workflow section, then open the UserSetting.js file with a text editing tool in order to replace the embedded assets with custom ones. |
| Modifications in the General Setting Section | ||||||
The settings in the General Setting section of
the UserSetting.js are listed below. You need to adjust the
text within the quotation marks following the names of each setting:
| Modifications in the Player Setting Section | ||||||
The settings in the Player Setting section of the UserSetting.js are used for introducing desired assets into the web player. Therefore, please make sure that each and every asset you are about to use are already put into the path as described in the General Setting Section as describe above.
The Player Setting section are as shown below:
| Modifications in the LevelSetting Section | ||||||
In this section, you are able to set the scoring and
level-setting regulations for
the quiz.
| Modifications in the QuizSetting Section | ||||||
In this section, you are able to design different questions for
the quiz, including the text, answers and the scripts for the
actor to speak.
