Main Menu - Edit
The Edit menu on the main menu bar contains all the commands for manipulating 3D entities in the scene.
Undo / Redo
(Ctrl + Z / Ctrl + Y)
Undo or redo the recorded last action.
Delete
(Del)
Deletes one or more selected objects.
Select
(Q)
Switches to select mode for picking objects.
Select All
Selects all objects in the scene.
Move / Rotate / Scale
(W / E / R)
Transforms selected objects - does not work on characters.
Attach (Detach)
Attaches an accessory to any bone in the character.
Preference
(Ctrl + P)
Displays the Preference panel in which you can adjust aspects of the authoring environment for Character Creator.
Project Settings
(Ctrl + Shift + P)
Displays the Project Settings panel in which you are able to convert all the materials in the project into PBR Shader or Traditional Shader.
Embed External Textures to Object
Embeds all the external textures into the current object.
Multi-Duplicate
(Ctrl + K)
Duplicates selected Props.
