Right-click Menu for Layer
If you right-click on either one of the layers, then the context menu will open.
Duplicate
Duplicate the currently selected layer.
Mask
Mask out the layer with a custom grayscale image.
Link Controls
This drop down list can be used to pick the desired material with the settings you want adjusted.
Delete
Delete the selected layer.
Delete All Layer
  • Current Material: Delete all layers in the current material.
  • All Materials: Delete all layers in all materials.
Move to
Move the selected layer to another material.
Notice that the layers whose Link Controls are activated can not be moved.
Flatten
Temporarily flatten the settings if there is no need for further adjustments of the layer.
Make Static
Un-flatten the layer's settings for further adjustments.
Merge Down / Merging Visible
Merge down all or all shown layers to the skin base layer in the Skin pane.
Re-ordering Layers
  • Bring Forward: Move the selected layer one level up.
  • Bring to Front: Move the selected layer to the top of the layer stack.
  • Send Backward: Move the selected layer one level down.
  • Send to Back: Move the selected layer to the bottom of the layer stack.
Refer to the Re-Ordering Layers section for more information about drag-n-dropping method to re-order the layer stack.
Show / Hide Layer
Show or hide the selected layer, all layers in the current material or layers in all materials.
Exporting Flattened Material Images
If a layer's settings are frozen or flattened to channel textures, you can export the textures to a desired folder.
Embed All Images
The external textures (linked) in the channels of the selected layer can be embedded into the layer by executing this command.
Set Effect Category
You can determine the category to which the layer belongs.
Rename
Rename the selected layer.
