AI Image Generator
The AI Image Generator allows you to create character images (Front, Side, and Body) using AI. The image generated with this tool matches our requirement for source photos automatically upon generating.
There are multiple entries scattered around to access the AI Image Generator, please refer to Entry for AI Image Generator for further details.
The AI Image Generator panel contains two primary tabs, Front and Side/Body, along with a shared Generate Result section for previewing and applying generated images.
Front
Inside are two subsections for generating the front image.Generate and Enhance.
  • Generate: Create a Headshot 3 front image by entering simple character traits such as gender and skin tone, while Headshot automatically determines angle and lighting. Output resolution can be set to 2K or 4K.
  • Improve an imported source image or a previously generated front image. Available options include Optimize, Remove Hair, Remove Beard, Remove Eyebrows, Remove Eyelash, and Remove Makeup. Optimize applies lighting, angle, cropping, expression, and black-and-white correction in one step. For further information, refer to Fixing and Enhancing Image.
Side / Body
Generate the Side and Body Image based on the front image.
See Also:
