Using Tracking Data Inspector after Version 1.1
Motion LIVE plug-in provides Tracking Data Inspector to display 42 Control Names (Face IDs) received from Faceware, or 58 Control Names (Face IDs) received from iPhone. For the following purposes:
  • No need to adjust expressions to compensate for bad data - adjust the data itself with the multiplier.
  • Make your own multiplier profiles for your own iPhone setup, as well as for individual subject's faces and individual characters.
  • You can get instant feedback over tracked data from these dynamic parameters.
  • Observe the relation between facial performance, analyzed Face ID stream and turn up or down the mapping sliders in kind.
  • Use the meters to determine whether to increase or decrease the data strength from the mo-cap devices.
  1. Make sure the default or added gears are launched and connected (green light) with Motion LIVE plugin.
  2. Click the Tracking Data Inspector button on the Motion LIVE panel.
  3. The Tracking Data Inspector panel will display on the screen. On the panel, Control Name Stream receiving status are shown and constantly changing.
  4. Type into the Control Name field to display a specific facial feature.
  5. Perform Signal-Multiplying by setting the values for the facial feature signals that are too strong or weak.
  6. In the Facial Motion LIVE panel, adjust the sliders in the Strength section to change the captured result in real-time.
  7. Alternatively, open the Expression Mapping Panel (updated after version 1.1) to exaggerate or ease the mapping result in accordance with the data status list in the Track Data Inspector.
