Actor - Look At Targets (New for 8.2)
You can rely on this time-saving feature instead of manually adjusting
the head of the an actor to follow a moving target.
- Create a character (e.g., T-rex) and an object or another
character (e.g., Coyote) with animations.
- Playback to view the animations.
- Select the T-Rex, in the Modify panel, scroll to the Look at section and click the Pick Target button.
- Click on the Coyote, the T-Rex will instantly lean and look at it.
- Optionally adjust the detail settings to modify the result of the looking-at.
- Play back and the character will look at the animating target.
Note:- You can have the actor Look At the target object over a certain period of time and then have it stop looking outside that time range.
You can optionally select the sub node of the target by clicking on the
button and select a desired node in the tree view.
The actor looks at the whole object (pivot)
The actor looks at the sub-node
(the speaker)
