In the iClone Indigo Render Settings panel, in addition to the
lighting method mentioned in the
Environment Settings section,
you are able to add additional iClone Lights for rendering the current scene
in Indigo.
1 |
Export Range |
To determine the range to export the current project to Indigo for rendering. You are able to render single frame or a series of frames. In addition to this, you are able to stop rendering a frame according to certain limitations. |
2 |
To simulate the photos shot by different type of films. |
3 |
Export Size |
To set the resolution of the target image or images without changing the original resolution of the iClone project. |
4 |
Options |
The parameters in this section allow users to use the Supersampling technique, save an IGI file, enable Aperture Diffraction, and select the Tracing Method. |
5 |
Export |
To export and convert the current iClone project into a Indigo scene (*.igs) or a series of scenes for rendering in queue (*.igq). |
Note: |
Please refer to the Render Settings section for more information. |
