Offsetting Objects on Motion Path
When an object is following a Motion Path, you can utilize the offset feature to adjust the entire route, and you can also key rotation and scale, in addition to employing the dummy method.
There are three types of offsetting: Move, Rotate, and Scale. The Move offset allows you to shift the entire path, creating a variant route and allowing you to position objects along the same path. Meanwhile, the Rotate and Scale settings are keyable, allowing you to adjust an object's rotation and size as it moves along the path.
Refer to the following topics for more information:
