Creating Morphing Sliders for Default Characters
Prepare a target character in OBJ or iAvatar format.
Launch Character Creator to have a female character loaded by
default.
Retrieve the default appearance of the character.
Note:To retrieve the default appearance of the character:
- Open the Modify panel.
- Switch to the Morphs tab.
- Select the Currently Used item in the tree view.
- Click the Reset button near the bottom of the panel.
Perform Create > Morph Slider Editor to open the panel.
Name the slider and add a path.
Note:For more information, refer to point 1 under the User Interface Introduction for Morph Slider Editor section.
Set Morph Value > Minimum to 0 and Maximum
to 100, so that when the custom slider is set to maximum
the character retains its original look.
To create a thumbnail, click the
button and load
an existing image.
In the Source Morph radio button group, choosing either the Default Morph or the Current Morph
option gives the same results.
In the Target Morph radio button group, choose the File one and load the character
prepared in
step 1 by clicking the
button.
Click the OK button to add your custom morph slider into the designated node
and path.
Drag the slider and you will see the default character is gradually transformed to the target character.
Value = 50
Value = 100
Note:The clothes of the target morph character will not be loaded and possess morphing behavior because they are different objects.
You can still use the default sliders to further adjust the new character.
