The UI Structure of PBR Substance
If you are using PBR Substance Presets (for skin, cloth or accessories), you should understand the interface structure of these presets.
UI Structure of PBR Substance for Clothes and Accessories
When you click the Select Substance Material button before launching the Appearance Editor for clothes and accessories, you will see three different PBR Substance Preset as shown below. They have identical UI structures only that the materials provided vary in amount.
  • Each PBR Substance Preset includes Mesh Data, Materials, Patterns, Decals, Global FX and Diagnostics items.
    Item Name
    Function of the Item
    Mesh Data
    It contains the Height, Normal, World Space Normal, AO and Color ID channels for the object. Please refer to the About Channels in Mesh Data section for more information.
    Materials
    It contains up to 7 different base materials.
    The deployments of these materials are determined by the textures loaded in the Color ID channel in the Mesh Data section.
    Patterns
    Use the settings under this item to create repetitive prints on the entire object.
     patterns are allowed to be applied and span across the entire object.
    Decals
    Use the settings under this item to create prints on the object.
    You are allowed to add up to three decals on the object.
    Note that the decals can be flat or embossed.
    Global FX
    In order to add more overall effects, you can adjust the settings in the Rips, Tweaks, Dust, Dirt and Fabric Holes sections under this item.
    Diagnostics
    The Diagnostics item is used to individually preview the maps and effects applied on the mesh of the object, such as the channels in the Mesh Data and the textures in different Materials.
  • By layering the effects from the items (Mesh Data, Materials, Patterns, Decals, Global FX), you are able to generate realistic PBR appearance material for the object.
    Initial Object
    Mesh Data Applied
    Material Applied
    Pattern Applied
    Decal Applied
    Global FX Applied
UI Structure of PBR Substance for Character
When you click the Select Substance Material button before launching the Appearance Editor for character's skins, eyeballs, finger and toe nails, teeth, tongue, and eyelashes, you will see PBR Substance Preset as shown below. The UI structures are different for different body parts and are described in this section.
Actor Head Skin (for CC1 characters only)
  • The PBR Substance Preset includes Skin, Tan, Freckles, Cosmetics, Hair, Decals and Eyelid.
    Item Name
    Skin
    It contains the Normals sub-item for adjusting the wrinkles, pores and textures, and Tweak sub-item for modifying the color tone on the face skin.
    Tan
    It can be used to simulate the suntan effect on the face skin.
    Freckles
    Use the settings in the Pattern sub-item to determine the scattering amount and density of the freckles on the skin and the ones in the Blend sub-item to blend the freckles to the original skin color tone.
    Cosmetics
    You can put cosmetics onto the character's face with the sub-items including the Blush, Lips, Eyeshadow and Eyeliner.
    Hair
    In the Scalp, Eyebrows, Mustache and Beard sub-items, you can have the character to put one different hairs on the face.
    Decals
    Use the settings under this item to create tattoos, paints, scars or wounds on the face skin.
    You are allowed to add up to three decals.
    Please note that the decals can be flat or embossed.
    Eyelid
    Use the settings in the Lacrimal and Eye Sac to determine the appearances of these two eye parts, including the color and the ability of reflecting the lights.
  • By layering the effects from the items (Skin, Tan, Freckles, Cosmetics, Hair, Decals and Eyelid), you are able to generate realistic PBR appearance material for the skin.
    Initial Face
    Skin Applied
    Tan Applied
    Freckles Applied
    Cosmetics Applied
    Hair Applied
    Decal Applied
    Eyelid Applied
Actor Body Skin (for CC1 characters only)
  • The PBR Substance Preset includes Skin, Misc, and Decal items.
    Item Name
    Skin
    It contains the Body Base, , Body Surface Normals, Body Freckles, Body Tan and Body Ambient Occlusion sub-items.
    These sub-items can be used to create different effect as described in the table above in the Head Skin section.
    Tan
    It can be used to simulate the suntan effect on the body skin.
    Freckles
    Body Hair
    Decals
    Use the settings under this item to create tattoos, paints, scars or wounds on the body skin.
  • By layering the effects from the items (Skin, Misc, and Decal), you are able to generate realistic PBR appearance material for the skin.
    Initial Face
    Skin Applied
    Tan Applied
    Freckles Applied
    Body Hair Applied
    Decal Applied
Actor Eyelash
  • The PBR Substance Preset i includes Base.Matte, Primary.Red, Secondary.Green and Tertiary.Blue items.
    Item Name
    Base.Matte
    It can be used to determine the base color and reflection of the primary and secondary eyelash layers.
    Primary.Red
    It can be used to overlapping color and reflection on the root of the primary eyelash layer.
    Secondary.Green
    It can be used to overlapping color and reflection on the secondary eyelash layer.
    Tertiary.Blue
    It can be used to overlapping color and reflection on the tip of the primary eyelash layer.
  • By layering the effects from the items (Base.Matte, Primary.Red, Secondary.Green and Tertiary.Blue), you are able to generate realistic PBR appearance material for the eyelashes.
    InInitial Eyelashes
    Base.Matte Applied
    Primary.Red Applied
    Secondary.Green Applied
    Tertiary.Blue Applied
Actor Finger and Toe Nails (for CC1 characters only)
  • The PBR Substance Preset includes Nail, Polish and Custom Texture items.
    Item Name
    Polish
    It is used to overlap different colors onto the nails.
    Tweak
    It can be used to determine the color and reflectivity for the nails.
  • By layering the effects from the items (Polish and Tweak), you are able to generate realistic PBR appearance material for the nails.
    Initial nails
    Tweak Applied
    Polish Applied
Actor Tongue
  • The PBR Substance Preset includes Base Color and Apex items.
    Item Name
    Base Color
    Use the settings in this sub-item to apply overall color and reflectivity to the tongue.
    Apex
    You can cover the upper surface of the tongues with the settings in this sub-item.
    Roughness
    The settings under this sub-item are used to determine the roughness of the tongue.
  • By layering the effects from the items (Base Color and Apex), you are able to generate realistic PBR appearance material for the tongue.
    Initial Tongue
    Base Color Applied
    Apex Applied
    Roughness Applied
