Concept Design - Single View (New for v5.2)
The controls in the Concept Design - Single View tab allow AI to generate front view image based on reference images or text prompts. The generated design image in the Single View mode can then be sent to the Mesh Generation tab, where AI uses it to generate a 3D mesh object.
Choose the Single View first to start this mode:
User Interface Introduction for the Single View mode
A
Mode Tabs
Switches between Concept Design and Mesh Generation modes.
  • Concept Design: Uses AI to generate reference images.
  • Mesh Generation: Generates a mesh from the images created in Concept Design.
B
Single View switch
Exits the Single View mode.
C
Mesh Type and Part
  • Choose the type of 3D mesh to generate: Character, Head, Clothes, Hair, or Prop / Accessory.
  • Clothes only. Select a preset for generating part-specific images.
D
Open Task Queue Panel
Opens the Task Queue panel, where you can view the AI processing history, retry or rework tasks, cancel or delete tasks, and locate the source files and view set.
E
Load Design Project
Loads concept design task previously completed.
F
Ref Image
  • Loads reference images into the image slots.
  • You can click either image slot and use the tools to load, paste, or delete reference images, or clear all reference images.
    1. Load Image: Loads a reference image from the desired directory into the focused reference image slot.
    2. Paste Image from Clipboard: Pastes an image from the clipboard.
    3. Delete Image: Deletes the image from the focused reference image slot.
    4. Clear Reference Images: Deletes all reference images from image slots.
G
Prompt
  • Enter a text prompt describing the details you want AI to generate.
  • You can also apply prompt Inspiration templates which provides a wide range of creative prompt ideas for different mesh types.
  • You can expand the prompt presets to manually edit the prompt details.
H
Smooth Edge
Removes visible seams from AI-generated images, especially for stylized characters.
I
Generate Target Front View
In this section, you can:
J
Send to Mesh Generation
Send the generated front image to the Mesh Generation tab.
