Using 3D Assets — Vehicles
With an AI Service subscription, AI Studio provides a wide range of vehicles that can be applied directly. You can place cars and bikes on streets or create dynamic traffic scenes to bring your environment to life.
Accessing Content
Open the Smart Search panel and select the AI Studio tab.
Vehicle content is available under
Prop > Vehicles Library, with tabs for switching between Item View and Pack View.
| Item View | Pack View |
If you are not subscribed to an AI service, free vehicle props are also available in the Samples content pack.
Downloading Content
Packs or items available for download are marked with a Cloud
icon in the top-right corner.
Double-click the content, right-click and select Install Content, or click the Install Content button at the bottom to download and install it.
Searching Content
Installed packs or items are marked with a Checkmark
Use Deep Search or Keyword Search to locate the desired vehicles.
Applying Content
Before applying vehicle content to the scene, you can use city elements from the Prop library in the free Samples content pack to establish a base environment.
Double-click the content, right-click and select Apply, click the Apply button at the bottom, or drag it directly into the scene to apply it.
Transforming Content
Use the Transform Tools to reposition the vehicle props to the desired locations.
Adjusting Camera Angle
Create a custom camera and adjust the camera angle to capture the vehicles from the desired viewpoint.
Sending to AI Studio
After placing vehicles in the scene, click Capture Image from 3D Viewport in the AI Studio Tools toolbar to capture the current viewport and send it to the 3D to Image tool in AI Studio.
3D Guided Gen
Finish the 3D to Image workflow to generate images in the preferred render style.
| Prompt | AI Output |
Completely maintain the camera angle, composition, and the proportions and appearances of the characters from Reference Image.
Video Gen
Use the images generated by 3D to Image as the Start Frame references, then proceed to the Video Gen workflow to generate a video.
| Prompt | Start Frame |
[Cinematography]: Low-angle ground tracking shot, shifting to frantic handheld "survivor" style. Extreme variable DOF: sharp focus on car textures, heavy bokeh blur on distant giant. Digital camera shake and thermal distortion during explosion.
| AI Output | |
