Using 3D to Image (v1.1.2)
The 3D Guided Gen tool creates images with defined objects, backgrounds, lighting, and render styles using a 3D viewport reference image and text prompt. Optional AI Actors ensure consistent characters across scenes.
See also: Tutorial - Directing AI with iClone 3D Guidance
Required Elements
  • Image: Captured Image from Viewport.
  • Prompt: Enter custom prompts manually, or apply preset prompts if you’re unsure where to start.
3D to Image Workflow
This workflow guides AI to generate optimized render results for existing 3D projects or previz assets. Select the 3D Guided Gen tool from the left AI Toolbar and complete the tasks in each section under the 3D to Image tab. You can collapse or expand a section by clicking its caption.
Refer to AI Model Selection for Image Generation to choose a model from the Model drop-down list. Available options include Flux 2 Max, Nano Banana Pro, GPT Image 2, and GPT Image 2.5.
Ensure that both an image and a prompt are provided to enable the GENERATE button at the bottom. Note the task price displayed above the button before clicking.
Track progress on the AI Render View or via the new entry in History on the right. When the submission completes successfully, the AI-generated image will appear.
Next, click the 3D to Video tab or use the 3D to Video command in the Quick Access Menu at the top of the AI Render View to load the newly generated image as the first frame for 3D to Video creation.
