Resetting Values
There are several methods to reset values for the settings in the Modify Panel.
Resetting Values of Slider Type
  1. Setting a value within a group by either way described in the Setting Values section.
  2. Double-click on one of the title of the slider, the value of it will be reset.
  3. Double-click on the group name and each value within the group will be reset.
Batch Resetting
If you want to reset a lot of parameters without double-clicking on the titles one after another, which can be tedious and time-consuming, then you may use the batch-resetting method listed below.
  1. Make sure the desired sliders for resetting are correctly shown in the right pane of the Modify panel.
  2. Click the Reset button at the bottom of the pane.
  3. Each setting listed will be reset.
