Preference Panel
You can access the Edit >> Preference command from the main menu bar or use the hotkey Ctrl + P to display the Preference panel.
Double-click on the caption to dock the panel to the docking place,
or undock the panel and make it float above the main program.
There are six sections included in the panel.
You may expand or collapse each section by clicking the
+/- symbol.
- Control section:
To define the object snapping method in the scene,
show/hide the transform gizmo,
and enable/disable motion clip auto-play and file compression.
- Grid section:
To adjust the grid settings,
including visibility, color, spacing and size.
- Display section:
To show/hide FPS information, world axis, dummy object and polygon count on the 3D viewer.
- Real-time Render Options section:
To determine the render quality in the preview window,
and switch on/off the LOD effect.
- System section:
To set the undo times,
determine the temp folder for saving temporary files,
and assign the external image editor for modifying texture images.
- Interface section:
To change the appearance of the user interface,
such as the icon and font size and the color theme of the main program.
3
The adjustable parameters associated with the current project.
4
There is a scroll bar at the right of the panel.
Click and hold the mouse down anywhere on it and
drag up/down to navigate the whole panel when it is
longer than one
page.
Alternatively, you may roll the mouse wheel to scroll it up/down.
5
Drag the border to adjust the width of the panel.
