Introducing Audio Driven Lip-Sync
By utilizing the AI-powered ACE A2F (Audio2Face) technology, you can introduce real-time lip-sync and expressions for speech animation.
Workflow of Audio Driven Lip-Sync
Refer to the illustration below to explore the audio driven workflow of the ACE system.
- Choose an A2F AI Model for the lip-sync style driven by audio.
- Optimize the received ARKit signal and adjust the morph strength.
- Enable the Emotions allowed to be triggered by LLM.
- Design the triggered Emotions by strength levels.
- Send the Audio2Face processing results to the Speech root.
Create an Audio2Face node to overview all of the related settings in the Speech Graph.
Right-click on the empty area of the graph, and select ACE-A2F > Audio2Face from the context menu.
The Audio2Face node is created for the following controls.
- Audio2Face Model: Accepts the selected AI model from the namesake sub-node.
- ARKit Tuner: Accepts calculated results from the namesake sub-node, which maps Audio2Face’s returned ARKit signal to the character’s default morphs.
- Face Tuner Mapper: Accepts calculated results from the namesake sub-node, which applies additional custom mapping on top of the ARKit Tuner.
- Lower Face Strength: Adjusts the strength of the mouth animation generated from the Audio2Face signal.
- Enabled Emotions: Allows LLM-driven control of specified emotional speech animations.
- Emotion Config: Outputs enhanced emotional mouth animations.
