Texture Channels Sub-section
A
Max Texture Size
Show / hide the A pull-down menu for you to choose the texture size generated by Headshot. Available options are 512 x 512, 1024 x 1024, 2048 x 2048, 4096 x 4096 and 8192 x 8192, with 4K being the default resolution of the generated head texture..
B
Auto Update
A checkbox for enabling auto update for changes made to the character’s texture among the whole Texture adjustment section, except for settings in Generate Skin Photo section and Color Setting section, for adjustments made in Generate Skin texture takes longer time to load and adjustments made in color settings are directly linked to digital human shader material.
C
Generated Skin
Stores the texture maps generated from the imported photo. Changes to these maps can be made via settings in the Generated Skin Photo section, refer to the page Generate Skin Photo for more information.
D
Blend Mask
Stores the Blend masks for blending skin photo maps and Base Skin maps. Changes to these masks can be made via settings in the Blend mask section, refer to the page Blend Mask for more information.
E
Base Skin
Stores the texture maps for Base Skin. Changes to these maps can be made via settings in the Base Skin section, refer to the page Base Skin for more information.
F
Texture Tools
A number of tools for managing and modifying the texture maps and masks.
  1. Load: Loading textures to a destined location.
  2. Save: Saving texture to a destined location.
  3. Copy: Copy the selected texture to clipboard.
  4. Paste: Paste the texture in clipboard to the selected channel.
  5. Adjust Color: Adjust the overall color level and color balance for the selected texture.
  6. Launch: Launch the selected texture to external image editing software for editing.
  7. UV: Launch the UV map of the selected texture to external image editing software for editing.
  8. Merge Correction Layer: Merge the Correction Layer into the diffuse map
G
Brush Tool
Activate the Brush Tool for direct painting on the character in the viewport.
  • Mask: Paint directly on the viewport to modify custom masks for covering artifacts.
  • Stencil & Clone: Paint directly on the viewport using a stencil to apply patterned textures or repair textures using the Clone Brush. Please refer to Theory for Stencil& Clone Brush Tool for more information
