Main Menu - Modify
The Modify menu on the main menu bar contains object-related commands.
Smooth Mesh
Enables tessellation for the character, hair, cloth and/or accessories , and Subdivision feature to increase the polygon count in real-time rendering for smoothing the geometry.
Bake Subdivision Mesh
Bakes the real-time subdivision result to the meshes of the props, giving higher polycount for smoother surfaces.
Edit Pose
(Shortcut: N)
Show / hide the Edit Motion Layer panel in order to assign a certain pose to the character.
Edit Facial
Show / hide the Edit Facial panel to assign a facial expression to the character.
Open Eyes
Opens or shuts the character's eyes.
Open Mouth
Opens the mouth of your character for viewing the teeth.
Hide Teeth
Hides the teeth in order to view the tongue.
Conform
Shows a panel with adjustable parameters for conforming the cloth or hair to the character.
This command opens the conforming window for you to adjust the cloth of the character in order to solve poke-through issues, smooth clothing, or adjust the size of clothing.
Cloth Layer Settings
This command opens the Cloth Layer Settings panel to customize the layer order of the clothes.
Hide Body Mesh Tool
Accesses the Hide Body Mesh feature.
Skin Weight
For manually setting the skin weights for the selected clothes.
Transfer Skin Weights
Automatically assign skin weights for the selected clothes with templates.
Facial Hair Vertex Assignment
When the smart hair mesh spans across different areas or the partial mesh drifts away from the skin, you can transfer skin weights from certain regions to the vertices of the hair meshes
Assign Conformable Regions
Unlike the eyebrows and beards, the hair on the head are not given skin weights when they are applied. Therefore, when the character performs facial expressions, the hairline around the forehead does not move along with the facial muscles, which can lead to mesh penetration.
Create Hair, Brows and Beard
Allows for the creation of custom hair, brows or beard.
Convert to Accessory
For converting hair, clothes, shoes, gloves into accessories for resetting the transformation or pivots position.
Merge Accessory
Merges accessories composed of multiple elements or merges the accessories applied on the character.
Merge Props
Merges props composed of multiple elements or merges the currently selected props.
Convert to Sub-item
Converts the elements of a prop or accessory to sub-items.
Remove Sub-item
Deletes the sub-items of a prop or accessory.
Merge Material (UV)
Merges all the materials when you export a FBX file.
Optimize Material
Decreases the total texture numbers by automatically sharing identical materials and textures.
Exclude Effect
Hides visual effects in the viewport by object or by special effect.
Edit Spring
Toggles the Edit Spring mode for setting the spring effects on chosen bones.
Rigid Body Simulation
Turns on/off the entire rigid-body simulation.
Soft Cloth Simulation
Turns on/off the entire soft-cloth simulation.
Collision Shape
Sets up the collision shapes on a target character.
